newbie question> cannot fillet or shel or offset this solid
All  1  2-4
1260.2 In reply to 1260.1
Select the half big rounded face : Fillet 0.05 = no problem :)
Or only the big arc if you want just fillet it
All works fine also for the bottom, under etc. :)
Seems you have just taken a more big angle!
EDITED: 12 Jan 2008 by PILOU
1260.3 In reply to 1260.1
Hi Rudy, like Pilou mentions maybe you were using too large of a fillet radius?
Over here selecting the whole solid seems to fillet fine up to a maximum radius of 0.17 - any much more than that and the little face will get totally consumed:
If fillet is failing for you, the first thing to do is to try using a really small radius, like 0.1 or 0.01 . If that succeeds you can start increasing it and look for the areas that are causing problems, such as a face being totally eaten away, pieces running into each other, etc...
Shelling can be kind of similar - over here shelling the bottom face of your solid seems to work fine up to a distance of 0.39. Any more than that and again pieces will start to run into each other and fail.
1260.4 In reply to 1260.3
Thank you Michael,
Thank you Pilou.
Appreciate it.
Rudy
Show messages: All  1  2-4
