Sketchup exchange
 1-3  4-23  24-43  44-63  64-66
http://en.wiki.mcneel.com/default.aspx/McNeel/ThreedWareHouse.html ;)
Interesting text : the author Tim Hemmelman can be joined
EDITED: 7 Jan 2008 by PILOU
1244.5 In reply to 1244.4
so... it is possible. and maybe not that difficult if one could borrow the rhino code.
worth looking into Micheal? this would take Moi to a very high level of demand very quickly. it would be a must have for all sketchup owners. personally i've been modeling for years and can't make heads or tails from Rhino, Moi on the other hand is a joy just like sketchup... i just can't think of a practical reason to buy Moi if i can't bring my SK models into it to finish them, then take them back to markup and render.
I don't want to offend, I love Moi, i'm just having a hard time to find an excuse to buy it. help me out here. ;-)
1244.6 In reply to 1244.5
Hi xrok1,
Yup, it is definitely possible - I'm sorry if I gave the impression that it was impossible, that's not what I meant to say earlier, I mean to say that there were issues that make it somewhat difficult, taking a fair amount of work to make it happen.
It looks like the Sketchup guys send out some I/O helper code to some companies who request it.
But the main difficulty that I mentioned earlier is still there - Sketchup uses polygons and MoI uses NURBS and does not currently work with polygon mesh objects (other than at export time). Rhino works with both polygon data and NURBS data, that is one reason why a Sketchup import into Rhino was not quite as difficult.
To make the import come into MoI I would probably have to implement polygon mesh objects as another type of object you could create and edit inside of MoI, which is a considerable amount of work especially trying to integrate them with commands like trimming and booleans, etc...
I don't expect to be able to complete that work anytime too soon.
Sorry! Unfortunately things that take a lot of work will take time before they can be implemented.
Well, if you buy it, it makes it more likely that I will be able to stay in business and eventually be able to handle your request instead of going out of business! :)
I have added Sketchup file I/O to the wiki wishlist.
1244.7 In reply to 1244.6
ok how about this. could one implement lets call it a sketch (or auto geometry mode?) mode that works like sketchup (sorry i can't get over the way sketchup works its spoiled me). now i know i can draw shapes directly on Moi objects such as a cube... but lets say in this mode i draw a line (circle, rectangle...) on a face, i could then extrude (in or out) either part of that face without splitting, booleaning, trimming... like sketchup. of course this wouldn't need to work with curved surfaces (i'm not greedy). Then i could use Moi instead of sketchup, have the perfect excuse to get Moi, and wouldn't have to put up with Sketchup's pitfalls.
Viola; best of sketchup, best of Moi. That would be just about a perfect modeller.
Sorry if i'm getting annoying. Tell me when to stop.
1244.8 In reply to 1244.7
here's an idea for easy implementation. if i preselect a object or a face before drawing on it, the shape drawn becomes part of the object and resulting faces can then be edited directly as part of the complete object.
SORRY! i can't stop. please stop me.....
1244.9 In reply to 1244.7
Hi xrok1 - I do want to experiment with what you are describing in the future (direct drawing on to surfaces), but it will also take a fair amount of work to accomplish that. It will involve modifications to each drawing command, and MoI has many of these commands.
For now I just kind of generally expect that if you want something that works exactly like Sketchup, that is already available to you by running Sketchup itself...
1244.10 In reply to 1244.8
Hi xrok1,
That's a good idea, but unfortunately planning out how something works is just one piece of the puzzle - actually making the code for each drawing command accomplish this is quite a bit of work...
It gets harder for things that have an impact on many different commands like this request.
With a quick count of curve drawing commands, it looks like this would involve work on 22 different commands.
It will tend to take me a while before I can get around to some items that take quite a bit of work to accomplish.
1244.11 In reply to 1244.10
Thanks for the consideration Michael, i definatly think this type of feature would sell alot of software for you (not to say that it won't sell great now). for now i have played a little to see if i could accomplish this functionality for myself somehow. here's what i've come up with: cube; draw line or other shape on side; boolean union if extrusion is inward and not touching existing edge or extrusion is outward; boolean difference if extrusion is inward and touching existing edge.
this gives me the results i want and is a lot more flexible than SK. now if i reverse my thought process, create in Moi then export to SK via .obj; which by the way Moi does a wonderful job with n-gons; i found my excuse, i'm happy again!
i think this is a problem not with Moi but with the workflow i'm used to. that being said if i could streamline this (draw; trim; extrude; boolean) process with a script or different workflow please let me know. i'd be happy with just being able to preselect a face and when i draw on it it automatically trims.;-)
your happy customer, xrok1
1244.12 In reply to 1244.11
Unfortunately, SketchUp can only import 3ds files, not obj. On the other side is difficult to handle high polygon objects in SU.
1244.13
Hallo all
The fact is that better cooperation between MOI and SU would be wery demanded. These sofwares are dedicated for similar group of users, both very intuitive using and completing together large possibilities. Both with connection with KERKYTHEA or INDIGO renderers give frofesional outcomes for designers. SU doesn`t import obj so I do it via 3ds.
Easy cooperation MOI and SU would be celebration for me.
Best regards
Olda Jirsa
Message 1244.14 deleted 7 Jan 2008 by PILOU
1244.15 In reply to 1244.13
.3ds doesn't seem to support n-gons, or maybe it does, i can't seem to find that option in Moi. 3ds would be preferable, but i use a ruby script to import .obj to Sketchup.
1244.16
In my opinion, the reason why MOI is so great and loved by a lot of us is because it is a >NURBS< modeler that's easy to use which allow you to>quickly build shapes and objects<.
What's you're asking of Michael to do now is add in some kind of>polygon editing toolset< which is asking him to add a bunch of additional code that is totally opposite from NURBS modeling (which is what MOI is, a NURBS modeler)
If you'd like to edit your sketchup models, I'd suggest using the inexpensive Silo 3D modeler or Hexagon - these tools (especially Silo) has a similar simple UI and workflow and will allow you to totally do what you need to a polygon model.
-Will
PS - All of us here I'm sure would like to see MOI sell like crazy in a bunch of different markets but again the whole reason why MOI is loved is because unlike polygon modelers, you can create shapes and objects way quicker by using NURBS modeling techniques.
Once you add back in polygons you're working with that "same ole" workflow that MOI originally got us away from!
If you really need NURBS and polygons, then I'd suggest you try Amapi Pro - (or probably better, Hexagon) but you're definitely not going to get that ease of use with the NURBS as with MOI.
1244.17 In reply to 1244.16
< really need NURBS and polygons, then I'd suggest you try Amapi Pro - (or probably better, Hexagon)
I am not sure that hexagon has nurbs inside ;)
http://www.daz3d.com/i.x/software/hexagon/-/feature_list?
1244.18 In reply to 1244.17
don't assume your the only one that knows the differences between nurbs and poly modelers.
it is an inconsistent statement that adding functionality to Moi would somehow deminish it?
I too love Moi thats why i'd like to see a few things that i can do in it now with 4 or 5 steps, be streamlined to 1 or 2. the functionality that i desire has nothing to do with nurbs vs poly is has to do with common sense workflow. i am a solidworks user so i know that this functionality that SK uses (push/pull) is actually more nurbs like than poly like. by the way i have poly modellers, sloppy and inaccurate. i'm a designer not an artist, i have no desire to model monsters.
1244.19 In reply to 1244.15
Hi xrok1,
Nope, .3ds only supports triangles. It also has several other limitations like no more than 65535 points or polygons in a single mesh object.
So you should only generally use it as a last resort option.
1244.20 In reply to 1244.19
thanks, thats what i thought or you would have already implemented the option.
BTW, any chance of a macro recorder in future versions? i think i could accomplish the workflow i desire with a macro.
and where is the documentation for script commands, maybe i could make a keyboard shortcut to accomplish my goals.
1244.21 In reply to 1244.20
Hi xrok1,
I'd like to do something for this eventually, but it is also not an easy task, it will take quite a while before I will get a chance to work on it.
There isn't any documentation for scripting yet - for version 1.0 I decided it was more important to create documentation just for the basic use of MoI instead of for scripting it.
It takes quite a bit of time and effort to create documentation, and also to support people doing scripting or programming type work, so this is likely to be another area that I won't really get a chance to focus on for a while yet, sorry!
I know that it is frustrating that MoI doesn't have all these features that you would like. Please keep in mind that MoI is at version 1.0 and some of these things will take some time before they can be implemented.
1244.22 In reply to 1244.21
thank again, but i have to say Moi being at a ver.1 level. is miles beyond lots of progs out there at ver.2 ,3.... that i won't even bother with after an hour or so of trying them out; crashes, incomplete (basic) tool set...
Moi even at ver.1 competes well with the best software out there! Keep up the great work.
1244.23 In reply to 1244.17
Hi Frenchy, correct, Hexagon isn't NURBS but it has pretty good 2d sweep capabilities so while it's a polygon modeler, you can create your base shapes using curves in a similar fashion to MOI. (actually Hexagon and Amapi are sorta related code wise - my problem with the software was the company's business practices. Polyloop.com has a lot of that history embedded in the messages there...)
XRok1, I'm not assuming what people do and don't know, except for the fact that they may not know about the two applications I mentioned.
Michael has mentioned several times that MOI isn't focused on poly editing (at least at this point in time) and I offered suggestions, Amapi probably being exactly what being asked for...
I can understand needing accuracy and that's why NURBS works so well for mechanical models.
But if SketchUp is delivering polygons, it's polygons that you'll need to edit. For polygon modeling accuracy, there's always Lightwave and Modo but they're certainly more than $200...
Personally I'm glad that MOI is exclusively a NURBS modeler, I'd like to stay away from polygons as long as possible for my mechanical models... (But I can understand the various desires to be able to do more within MOI.)
-Will
Show messages:  1-3  4-23  24-43  44-63  64-66
