Sketchup exchange
 1-16  17-36  37-56  57-66
1244.37 In reply to 1244.36
which modelling program do u use.
I ask because (someone please correct me if i'm wrong) you should be able to take an .obj with ngon divisions out of Moi and apply cat-mull division in another modeller that supports it (not 100% sure, do some experiments)?
1244.38 In reply to 1244.37
Hi XROK1,
Just like you I have no desire to make monsters.Currently the only SDS modeler I have is Delftship (a great application for boatdesign). It uses natively SDS based on rectangular (Catmull-Clark) topology. It´s also able to import NURBS (via IGES) but only untrimmed NURBS. I was hoping that by tessellating my trimmed NURBS files to OBJ, STL or any other common triangle based mesh and subsequently converting it (if possible) to rectangular Catmull - Clark topology I would be able to bypass the "trimmed NURBS" import problem.
Delftship is not able to import .obj, it however imports VMRL 1 and I was hoping to use that route for getting my trimmed NURBS converted into Catmull Clark into the application.
P.s. attached is a screenshot from Delftship.
All the best,
The Lapstrake Lover
1244.39
One more thing.
Here is a link to an article on the currently hot and exciting subject of bridging NURBS and SDS.
http://portal.acm.org/citation.cfm?doid=1138450.1138455
1244.40 In reply to 1244.37
Moi's n-gon meshes are not suitable for subd smoothing because the extra vertices which create the n-gons are not matched up to the vertices on the coneccted faces. The exceptions would be more simple objects such as a cylinder or box. But then you might as well have modeled them in subd to begin with...
NPower makes a 3dsMax plugin which translates trimmed nurbs objects into quad meshes which can be smoothed as catmull-clark subd...
jonah
1244.41 In reply to 1244.40
JBShorty,
Thanks for the tip. The tessellation to of trimmed nurbs to quads mesh is exactly the thing I have been looking for. Unfortunatly, the cost of 3DSMAX + NPower + the quads mesh plugin is too great to be justified by just this minor requirement:-(
Are you aware of any other application (and perhaps not as expensive) able to tessellate trimmed nurbs to quads mesh??
1244.42
By the way, here is another link to info on the interesting topic of bridging NURBS and subdivision surfaces:
http://www.cgv.tugraz.at/CGV/research/NURBSUBS/esubs.html
1244.43 In reply to 1244.41
The Next Engine 3D Scanner comes with software for handling scan data. And in the demo video you can see when they automagically skin a mesh with a whole network of Nurbs patches. Assuming they are all untrimmed 3 and 4 sided nurbs patches, they could easily be reparameterized to some uniform spans in U and V directions, then extract the control polygons from the Nurbs patches. And that should be close to subd ready (at least enough that some minor hand work could fix in a short time). So i think there are solutions out there, just not in obvious places. And not always budget-minded...
jonah
run the "Scan Studio Core" demo video and watch closely at the topic labeled "Surfaces"
https://www.nextengine.com/indexSecure.htm
1244.44 In reply to 1244.38
Boatstalker.
I have been using Blender for rendering and noticed that it does export in VRML 1.0 and VRML 97 format.
Perhaps you can import into Blender ( there is a Python script (Blender Importer) in the Stand Alone Utilities, located on the Scripts page and it works very well) then export to you other program, And of course Blender is as free as a bird.
Maybe this might solve your problem.
http://kyticka.webzdarma.cz/3d/moi/ Custom Commands at the bottom.
Best wishes.
Malc
1244.45 In reply to 1244.40
Hi Jonah, that's not correct, there should be a complete alignment between all vertices of adjacent polygons across a joined edge.
If there is any mis-matching, then either you have an unjoined edge in your NURBS model there, or you've run into a bug.
Can you please post an example of the non-matching vertices that you're talking about so I can see what is happening for you?
1244.46 In reply to 1244.45
sorry, i phrased my statement incorrectly. It's not the vertices which cause the smoothing problem. It's the edges which don't meet up at the ends. Most of them form a "T" where the edge terminates, which is not ideal for subd...
jonah
1244.47 In reply to 1244.40
Hi Jonah, maybe what you mean here is that the underlying quad mesh (before it becomes n-gons) is not perfectly aligned between all surfaces?
By this I mean the quad "posts" that form polygons internal to each surface.
That quad structure follows the UV layout of each surface, so it isn't typically feasible to get identical quad structure between different surfaces that meet along a trimmed edge instead of along a natural surface edge.
Things like cylinders or spheres with symmerical cuts can often align along a natural surface isoparm, but when you just boolean 2 shapes together it isn't typical for the surfaces to meet at an isoparm.
It's basically the same problem as trying to reconstruct a complex model made up of booleaned parts by using only one single big untrimmed surface.
So certainly MoI's mesher won't do that, but every vertex on every n-gon there will be a matching vertex on the adjacent face though, making a "water-tight" mesh.
In the future there will be a few things I can do to increase quad-structure alignment in some different cases, like for fillets that have a plane on one side and a curved surface on the other side.
Doing all matching quads along every edge is a lot harder problem - it means creating a mesh that is not initially aligned to the natural UV grid of the surface, which doesn't really fit very well with some of the normal processes of surface algorithms such as splitting surfaces into smaller ones which has to happen along UV iso boundaries.
1244.48 In reply to 1244.46
Hi Jonah, it is kind of a general problem that arbitrary n-gons and subd do not mix well, regardless of a "perfect" vertex alignment.
Part of the sub-d process involves taking a centroid of the polygon, and if your polygon is not a convex shape, it won't have a nice centroid-ization to it.
Here's an example:
From an n-gon structure standpoint, that is pretty much a perfect mesh structure with a minimal amount of vertices. Yet regardless if you try to sub-d it, it will work but the result will be ugly as pieces radiate toward the centroid of the n-gon and kind of fold over the concave areas.
For nice sub-d-ifiying, you don't really want minimal vertex count n-gons at all, but rather a set of convex polygons even if that requires adding a lot more points to the entire mesh.
It's a completely different thing... Just more vertex alignment does not solve the problem.
1244.49 In reply to 1244.44
Hi Malc,
Currently, Blender doesn´t import NURBs .
However, take a look at the German video on ESubs (extended subdivision surfaces). Imagine modeling with MoI featuring an ESubs kernel and the possibility of being able to click a "convert to subdivision surfaces button" which would convert the NURBS model to SDS for further refinement. Imagine the possibility of being able at the click of a button to go to NURBS mode and SDS mode back and forth directed by which modeling method suits you each time, until your model is perfected.
http://www.cgv.tugraz.at:28888/CGV/research/NURBSUBS/_id246b1_
Best Regards,
Boatstalker
1244.50 In reply to 1244.49
Boatstalker.
So what you are saying, is that when a file is imported, it is converted to a poly mesh and does not retain the Nurbs and thats not what you want.
I have very limited knowledge of programing, so I find it hard to grasp all the different formats.
I am basically an amateur artist that finds 3d modeling an extension of my artistic capabilities and quite a challenge sometimes.
Blender is a challege with it's millions of buttons to learn, whereas MOI (Thankyou Michael) is a joy to use, so I tend to use the software and hope that it comes out ok, without having to understand how I got to the end result.
That software certainly looks awsome.
Hope you succeed in your goal.
Malc
1244.51
boatstalker, you might want to try this. not sure if it will work but it seems promising. let us know;-)
http://www.freedesign-inc.com/products.html
1244.52 In reply to 1244.48
Hi Michael. I understand it is more complex than what i mentioned, it was just the minimum example of a simple object which could be exported from Moi and be ready for sds (or at least with minimal amounts of mesh refining)...
jonah
1244.53
Some thoughts.
>I have added Sketchup file I/O to the wiki wishlist.
I am a big fan of the rush/pull tool my self , www.sketchup.com, www.3dvia.com/shapeit, With Models Ready for Microsoft Virtual Earth , Oh yes lets keep Microsoft happy too, haha very funny.
But anyhow I see Moi as an professional app and not as an BART SIMSONS TOY, Don't get me wrong but I dot see any reason for a Moi/SUp/Moi link, (they should meet else were).
Moi has already reach the professional circles and that is were it should aim at. Modo, 3dsmax,SolidWorks, bunkspeed, Maxwell... users love it, even Rhino users ask help from Moi.
Yet Limited supported formats, the ones there ROCK.
>Well, if you buy it, it makes it more likely that I will be able to stay in business and eventually be able to handle your request instead of going out of business! :
I wish I had a huge Studio to fill it with Moi, but that is not the case, although my check is ready.
>Hi xrok1 - I do want to experiment with what you are describing in the future (direct drawing on to surfaces)
yes pls.+1
>http://www.wtools3d.com/swf/tutorials/RTboolean/RTboolean.html + Some cool tricks on Inserting Doors and Windows http://www.ilexsoft.com/highdesign/media.html + http://www.visualarq.com/
Yes to somethink like that, but Micheal we can do better.
1244.54 In reply to 1244.51
Hi XROK1
http://www.freedesign-inc.com/products.html <
Actually I already have FreeDimension ;-). As an organic free form modeling tool it is brilliant. Using it is pretty much like sculpting some kind of a digital clay or jelly. The concept it´s based on is equally brilliant (adaptive/dynamic polygon mesh surface interpolation between (2+n)-sided patches defined by interconnected freeform curves). FreeDimension is polygon mesh based and it is an excellent concept modeler, especially when it coms to free flowing shapes.
However, if you want to make precision "man made like objects" NURBS is the way to go and MoI´s unique brilliant user interface makes it the modeling application of choice.
P.s. FreeDimension has the ability to export NURBS if the iges exporter plugin is purchased, so FreeDimension + MoI might be a quite powerful combo in the hands of a skilled artist/designer.
Hope this helps.
All the best,
Boatstalker
EDITED: 12 Jan 2008 by BOATSTALKER
Message 1244.55 deleted 12 Jan 2008 by YANNADA
1244.56 In reply to 1244.54
If it has not been mentioned before,
Carrara6Pro (probably any version) just LOVES working with MoI stuff, especially in the Vertex(Poly) room.
I usually save as IGES files from MoI as it makes shading (shading domains) a breeze in Carrara.
Carrara6 Pro, MoI and 3D Brush (and PhotoshopCS3 Extended)
The only way to live!
Show messages:  1-16  17-36  37-56  57-66
