Sketchup exchange
 1-6  7-26  27-46  47-66
1244.27 In reply to 1244.25
< but I couldn't figure out how to make a wall say 15 feet or make things to a specified sizes (in Sketchup)
Depend of Unities
Just Type 10,200 (page right bottom) if you want a rectangle 10m *200 m and press P (for push) and type 2.4 if you want 240 cm hight :)
But you can make the same with the mouse :)
EDITED: 9 Jan 2008 by PILOU
1244.28 In reply to 1244.17
Thanks for the tip, I'll take another gander at SU when I get time. ;-)
-Will
1244.29 In reply to 1244.28
yes SU is very similiar to Moi in that you can type your dimension directly after you start your action, move, draw, extrude... check out the video tuts on-line, very user friendly. you too will start to wish every program worked the same way after useing it for even 15 mins.;-)
Something very cool
you can export from Free Google Ketchup to the free Kerkythea with no limit of size for the rendering!
You can also export directly in Kerkythea from Moi in format OBJ ;)
Exporter is su2kt 3.0
http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=select&id=7
Kerkythea http://www.kerkythea.net/joomla
It's better than the 500*500 of Podium (in free)
Here my try of Podium model by Michelle Kaufmann (it is not a Moi model) you can load it at Warehouse http://sketchup.google.com/3dwarehouse/search?q=michelle+kaufmann&btnG=Rechercher&styp=m
and my try with the same in Kerkythea
1244.31 In reply to 1244.30
try Indigo its much nicer.
http://www.indigorenderer.com/joomla/
see images:
these were modelled in SK.
1244.32 In reply to 1244.31
< try Indigo its much nicer.
but maybe not so easy to manage ;)
And gallery Interior or Exterior architecture by Kerkythea is no so bad ;)
http://www.kerkythea.net/joomla/index.php?option=com_wrapper&Itemid=77
1244.33
Cool renders, guys! :-)
-Will
1244.34
Interesting thread here on polys. Personally I agree with XROK1 that I would like to see MOI stay as clean from polys as possible. Maintaining simplicity is vital. Once too many functions or tools have been added to an application it becomes overwhelmingly complex and that attractive user-friendlyness would soon be lost.
However one thing I have been thinking about is if you guys out there know of any application that is able to translate standard polygon meshes e.g. OBJ or STL into Catmull-Clark subdivision surfaces. Such an application if existent opens the door to translating trimmed NURBS into subdivision surfaces for postprocessing surfaces where more sculpting flexibility is needed.
Is there perhaps something available out there that is able to directly translate trimmed NURBS into SDS?
P.s. I think T-splines has not yet the ability to translate trimmed NURBS into SDS.
All the best,
The Lapstrake Lover
1244.35 In reply to 1244.34
why not just take an .obj/ngon export from Moi into any app (ie Modo) capable of SDS, and apply SDS to it?
it works for me.
1244.36 In reply to 1244.35
XROK1, Maybe that´s not such a bad idea. My apologies for asking silly questions, but I am not familiar with MODO or any of these high end polygon/SDS modeling applications.
However I have specific topological requirements. I want to convert meshes based on triangles into Catmull-Clark subdivision surfaces having a rectangular controlpoint grid. Is modo capable of translating meshes consisting of triangles into SDS divided by a recangular control point grid? Direct translation of NURBS into rectangular SDS topology l is easy, but when the NURBS has been trimmed things become complicated.
1244.37 In reply to 1244.36
which modelling program do u use.
I ask because (someone please correct me if i'm wrong) you should be able to take an .obj with ngon divisions out of Moi and apply cat-mull division in another modeller that supports it (not 100% sure, do some experiments)?
1244.38 In reply to 1244.37
Hi XROK1,
Just like you I have no desire to make monsters.Currently the only SDS modeler I have is Delftship (a great application for boatdesign). It uses natively SDS based on rectangular (Catmull-Clark) topology. It´s also able to import NURBS (via IGES) but only untrimmed NURBS. I was hoping that by tessellating my trimmed NURBS files to OBJ, STL or any other common triangle based mesh and subsequently converting it (if possible) to rectangular Catmull - Clark topology I would be able to bypass the "trimmed NURBS" import problem.
Delftship is not able to import .obj, it however imports VMRL 1 and I was hoping to use that route for getting my trimmed NURBS converted into Catmull Clark into the application.
P.s. attached is a screenshot from Delftship.
All the best,
The Lapstrake Lover
1244.39
One more thing.
Here is a link to an article on the currently hot and exciting subject of bridging NURBS and SDS.
http://portal.acm.org/citation.cfm?doid=1138450.1138455
1244.40 In reply to 1244.37
Moi's n-gon meshes are not suitable for subd smoothing because the extra vertices which create the n-gons are not matched up to the vertices on the coneccted faces. The exceptions would be more simple objects such as a cylinder or box. But then you might as well have modeled them in subd to begin with...
NPower makes a 3dsMax plugin which translates trimmed nurbs objects into quad meshes which can be smoothed as catmull-clark subd...
jonah
1244.41 In reply to 1244.40
JBShorty,
Thanks for the tip. The tessellation to of trimmed nurbs to quads mesh is exactly the thing I have been looking for. Unfortunatly, the cost of 3DSMAX + NPower + the quads mesh plugin is too great to be justified by just this minor requirement:-(
Are you aware of any other application (and perhaps not as expensive) able to tessellate trimmed nurbs to quads mesh??
1244.42
By the way, here is another link to info on the interesting topic of bridging NURBS and subdivision surfaces:
http://www.cgv.tugraz.at/CGV/research/NURBSUBS/esubs.html
1244.43 In reply to 1244.41
The Next Engine 3D Scanner comes with software for handling scan data. And in the demo video you can see when they automagically skin a mesh with a whole network of Nurbs patches. Assuming they are all untrimmed 3 and 4 sided nurbs patches, they could easily be reparameterized to some uniform spans in U and V directions, then extract the control polygons from the Nurbs patches. And that should be close to subd ready (at least enough that some minor hand work could fix in a short time). So i think there are solutions out there, just not in obvious places. And not always budget-minded...
jonah
run the "Scan Studio Core" demo video and watch closely at the topic labeled "Surfaces"
https://www.nextengine.com/indexSecure.htm
1244.44 In reply to 1244.38
Boatstalker.
I have been using Blender for rendering and noticed that it does export in VRML 1.0 and VRML 97 format.
Perhaps you can import into Blender ( there is a Python script (Blender Importer) in the Stand Alone Utilities, located on the Scripts page and it works very well) then export to you other program, And of course Blender is as free as a bird.
Maybe this might solve your problem.
http://kyticka.webzdarma.cz/3d/moi/ Custom Commands at the bottom.
Best wishes.
Malc
1244.45 In reply to 1244.40
Hi Jonah, that's not correct, there should be a complete alignment between all vertices of adjacent polygons across a joined edge.
If there is any mis-matching, then either you have an unjoined edge in your NURBS model there, or you've run into a bug.
Can you please post an example of the non-matching vertices that you're talking about so I can see what is happening for you?
1244.46 In reply to 1244.45
sorry, i phrased my statement incorrectly. It's not the vertices which cause the smoothing problem. It's the edges which don't meet up at the ends. Most of them form a "T" where the edge terminates, which is not ideal for subd...
jonah
Show messages:  1-6  7-26  27-46  47-66
