Mirror
1229.1
Hi. Mirroring a curve makes a linked copy. Is there a way to disable the link? So that it no longer influences the other curve.
1229.2 In reply to 1229.1
Hi Val - there is - select the mirrored object, the one that was created by the mirror command, and then run Edit / History and click the "Disable update" button that will show in the upper-right corner in the command options area.
That allows you to turn off history updates for any object that you want to have left alone.
1229.3 In reply to 1229.2
Thanks Michael.
