Regenerate option?
All  1-3  4-7
1223.4
Hi all,
I think that the 'Rebuild' funtion need to be in MoI. If imported curves are not so good -many points, kink, etc -, these need to be adjusted to get good surfaces and solid.
momso
1223.5 In reply to 1223.4
Hi Momso, I do plan to add it for V2.
For V1 I just did not have enough time to work on it, the tricky part is finding a good place in the UI to place it.
1223.6 In reply to 1223.5
In the Edit next to History there can be Object Properties
1223.7 In reply to 1223.6
I'm thinking of putting in a kind of object properties panel that would show up automatically in the upper-right corner area when something was selected. It would only show up when you were in selection mode (when you are not running inside of a command). It will take some time to experiment with this though, so that's why I postponed it until v2.
Show messages: All  1-3  4-7
