New Dec-28 beta now available
 1-2  3-22  23-30
1217.23 In reply to 1217.14
Hi Petr,
Thanks for pointing this works also in Rhino.
Actually I found that in Xara (another well programmed software but for 2d vector illustration) there's a similar behavior, while pressing shift to add objects to selection, it ignores background objects when dragging a marquee.
It's small details that makes great tools!
Regards,
Marc
1217.24 In reply to 1217.22
Ok. That sounds reasonable to me.
And how do you feel about the possibility to pass the location of moi.ini file as an argument to moi.exe? I know the people who prefer different color settings when working daytime versus at night or it would be useful to keep the complete default look...
I also wish to have a separate undo/redo stack for "viewport changes" like in Rhino (Home/End).
Petr
1217.25 In reply to 1217.24
Sounds like a good idea - in fact so good that it should be working already! :)
If you have spaces in any part of the .ini file name, make sure to surround it with " " quotes.
You should also be able to use this to specify the .ini on a network share so that copies of MoI on different machines can all use the same settings file.
Let me know if it doesn't seem to be working as expected.
I've added this one to the wiki wishlist.
1217.26 In reply to 1217.25
Hmm... Is it necessary to include some switch like /ini= or -i ?
For example, this doesn't seem to work.
"C:\Program Files\MoI beta Dec-28-2007\moi.exe" c:\moi.ini
Petr
1217.27 In reply to 1217.26
Hi Petr,
Oops - it is supposed to work like you have it there, but there is a bug messing it up. I have fixed it for the next (and probably final) patch which I am going to try and gather together tomorrow.
I also have things fixed up so that selection is restored if you do a cancel or undo. So for example if you select some edges and then run Fillet, and then cancel, the original edges will be selected again.
1217.28 In reply to 1217.17
Hi Petr, re: window deselection - It is a little more complex than I want to deal with right now setting up a fully scriptable method (since you have to do stuff like wait for an initial click, etc..). But I have added the ability to use the Ctrl key to do deselection.
This will work with either a "normal" window started by clicking in open space, or with the shift+ctrl forced method that I mentioned earlier - after starting the forced window, release shift and keep ctrl down to make it do deselection instead.
The scriptable method will have to wait until v2 when I get a chance to jazz up more scripting stuff.
1217.29 In reply to 1217.25
This would be a great feature indeed.
Marc
1217.30 In reply to 1217.28
Hi Michael, The deselection using the Ctrl key is really good choice... I think the scriptable method to do deselection is no longer necessary! -Petr
Show messages:  1-2  3-22  23-30
