Boolean
12092.1
Hi
I'm having trouble getting the lid of this case to look like the one in the attached image. I've removed the hardware to make it easier to adjust. I hope someone can help me.
Thank you so much for your help.
Size: 198.2 KB, Downloaded: 30 times, Dimensions: 1254x1254px
12092.2 In reply to 12092.1
you speak about these not very visible things ?
My Moi French Site
12092.3 In reply to 12092.1
Hi Booleano, is it the purple lining that you're trying to make?
That's something you would do with texture mapping in a rendering program, a CAD program like MOI is not suitable for that area.
12092.4 In reply to 12092.1
Hi Booleano,
is it the hinging you are struggling with ?
See photo.
Barry
12092.5 In reply to 12092.2
Hi PILOU
Hi Michael
No, that image is just for reference; I got it from "ChatGpT". What I want is to be able to position the selected figure in my "Guitarra Tasman_2_A.3dm" file.
EDITED: 26 Aug by BOOLEANO
Size: 89.5 KB, Downloaded: 15 times, Dimensions: 1323x1027px
12092.6 In reply to 12092.4
Hi Barry-H
That's what I want to do, but I don't know how. Could you do it for me in my file "Guitarra Tasman_2_A.3dm"? This is the last step I need to take to finish it.
Thanks in advance.
12092.7 In reply to 12092.6
So ;)
Draw any line where you want an axe of rotation!
12092.8 In reply to 12092.6
Hi Booleano.
to get the 3 hinges shown on your photo it was necessary to modify
your case profile so that it touches the hinge axis in 3 places.
Basically if you create a profile curve and the axis line you can mirror
about the axis to get the case top then rotate it about axis to get what you want.
Anyway attached is my file.
hope this helps.
Barry
12092.9 In reply to 12092.5
Hi Booleano, for the hinge placement it would probably be best to start with the lid in its fully closed position like this:
Then to have 3 hinges you need a "hinge axis" line like Barry shows above, which should graze the profile curve in 3 spots.
When you want to set the case to its open position you would select the lid and run the Transform > Rotate > "Rotate Axis" command.
This one here, not the regular 2D rotate:
That one allows you to pick 2 points for the rotation axis, you would pick the 2 points along the hinge axis.
But in your case it is not possible to create the 3 hinges because your outline does not graze a common line in 3 spots.
It is probably a good idea to draw in the hinge axis early in your modeling process so that you can make sure you are making a shape that will work with 3 hinges.
For your current shape you would only be able to make 2 hinges with a hinge axis like this:
