Unable to create Direct3D9 Device
All  1-4  5-8
1205.5
Hi
MoI works correctly in old PC AMD atholon 850 MHz Ram 256 MB Nvidia G-Force 400 64MB
Merry Christmas and happy New Year
Best regard
Juan Galvan
1205.6 In reply to 1205.5
Hi Juan, Merry Christmas!
If you do want to upgrade your machine, the #1 thing that I would recommend would be to add more system RAM.
That's usually the single biggest thing to speed stuff up, because once all your regular 256 MB is filled (which can happen fairly easily once you start building more complex objects and running more than one program at at time) Windows will start swapping chunks of memory back and forth to your hard disk which is so so much slower than having everything fit in RAM.
An older machine can work pretty well, but it does help a lot to have the maximum amount of RAM that will fit on it.
1205.7 In reply to 1205.6
Merry Christmas Michael:
With a new PC better MOI will run it is to demonstrate that MOI adapts to almost any system with modest video card.
A question:
what would it happen if the HD was damaged and do I lose all the information?
can I install MOI in another PC? comercial version.
Best regards
Juan Galvan
1205.8 In reply to 1205.7
Yup, that's true! I just wanted to mention the system RAM because adding more system RAM is a pretty easy way to make an older machine run more smoothly (for a lot of things, not just MoI) with only spending a small amount of money.
When you have less than 512Mb of system RAM, it can tend to get all occupied pretty quickly.
Well I hope that you are making backups of your important documents and models so you don't permanently lose anything that you have worked on!
Yes you will be able to do this - the commercial MoI will not be locked down to only be installed on a single machine.
That is becoming a lot more common these days, but I think it can too easily cause problems.
Show messages: All  1-4  5-8
