Script question
12047.1
This script works fine for toggling between two views - front and back:
script:var vname = 'front'; var vp = moi.ui.mainWindow.viewpanel; if ( vp.mode == vname ) vp.reverseView( vname ); else vp.mode = vname;
I would like a script that would just go to the specified view and NOT toggle.
Is that possible?
Thanks much.
Frederick
12047.2 In reply to 12047.1
Hi Frederick, try this:
script:moi.ui.mainWindow.viewpanel.mode = 'front';
12047.3 In reply to 12047.2
That was simple.
Thanks.
But it seems "back" is not a valid value.
So is there a way to get a non-toggling back script?
Frederick
12047.4 In reply to 12047.3
Hi Frederick,
The script above should do that.
That will set the view tab to this one without flipping it:
Maybe I'm not understanding what you mean by "non-toggling" ?
12047.5
I use this on ver 4
script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
It works on whichever view the mouse is over
cheers
shayne
EDITED: 22 Jul by SHAYNO
12047.6 In reply to 12047.4
The script I posted that had "reverseView" in it toggled between, in this case, front and back.
You posted this:
I wanted a script that would always and only change to front view AND a script that would always and only change to back view.
Your script seems to change to the "button" which does the front/back toggle without setting the "button" to front.
Thanks.
Frederick
12047.7 In reply to 12047.6
Hi Frederick,
Sorry, I thought that the "not toggle" part meant to not change between front and back.
Do the "Set front view" and "Set back view" scripts from here do what you need? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
12047.8 In reply to 12047.7
But they will toggle between, say, front and back.
Is there a script that will change to the correct tab AND select a specific view - such as front - without toggling to back on the next running of the script?
Frederick
12047.9 In reply to 12047.8
Hi Frederick,
The "Set front view" and "Set back view" scripts from here do that:
12047.10 In reply to 12047.9
The names of the view, "Front", "Back", etc. are case sensitive.
I did not know that until now.
I had lower case names and the script still shifts to the correct tab but then it just toggles between the two options, like front and back.
It is clearly recognizing "front" because trying "xront" yields an error.
Why does a lower case name result in the toggling whereas an upper case name does not?
Curious stuff.
Thanks.
Frederick
12047.11 In reply to 12047.10
Hi Frederick,
The error when using 'xront' is reported as an invalid function argument in the call to vp.reverseView().
I think the problem is something like one part of the script (the == operator) requires an exact case match with what is returned from viewpanel.mode while the parameter in the function call to reverseView() can tolerate different cases.
Do the scripts at https://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2 do what you wanted?
12047.12 In reply to 12047.11
Hi Michael
Yes all is good.
The problem was my use of all lower case names instead of having the first letter a capital.
Perhaps a code fix is in order so the case of the names doesn't matter so the scripts in all cases work as intended.
Thanks.
Frederick
12047.13 In reply to 12047.12
Hi Frederick,
That's something that would need to be fixed in the script.
Where your script is calling if ( a == b ) that's going to be a case sensitive comparison, that's how the Javascript == operator works with strings.
If you want it to be case insensitive you could do something like if ( a.toLowerCase() == b.toLowerCase() ) instead.
12047.14 In reply to 12047.13
Understood about the behavior of ==.
But I was referring to this:
"while the parameter in the function call to reverseView() can tolerate different cases"
Why is it desirable that that function isn't case sensitive.
Not a big deal, just curious.
Frederick
12047.15 In reply to 12047.14
Hi Frederick,
It's a general design goal for the script API to try to do something with what it is given if it can reasonably figure it out.
12047.16 In reply to 12047.15
Thanks for the info.
Let me see if I have this all now:
The != below IS case sensitive
vp.getViewport(vname).name != vname
The function below IS NOT case sensitive
So is there a function to compare two strings that is not case sensitive OR has an additional parameter that chooses between being case sensitive or not?
Thanks.
Frederick
12047.17 In reply to 12047.16
Hi Frederick,
Yes, for example if you run this script:
moi.ui.alert( 'test' != 'Test' );
result is: 'true'
Yup.
There is. Try doing a web search for "javascript string compare ignore case", there is a whole lot of information online about Javascript language functions.
12047.18 In reply to 12047.17
You are the best.
Frederick
