3dm v6 conversion to 3dm v4 or v5 on a Mac?
12039.1
Dear forum.
I wish to convert a STL file to a 3dm file to open in MoI but all online converters only give me v6 files- which I can't open in the current version of MoI.
I know there is a free translator available called Rh3dmConverter that some clever bod has very kindly written but alas it only works on Windows.
There is a converter for Mac for Food for Rhino, but every time I land on the page my browser greys the screen and I can't download.
Any suggestions?
PS, and OT I'm now quite excited as I can finally afford to buy a seat of MoI3D which I will do later today!
kind wishes,
Tom
12039.2 In reply to 12039.1
Hi Tom, an STL file only contains triangle mesh data, not CAD surfaces and solid data.
Probably the STL converter will generate a polygon mesh object in the Rhino file, and MOI will not read those types of objects.
There is a converter for 3DM Rhino v6 to Rhino v5 converter available here (both Windows and Mac):
https://moi3d.com/resources#Rhino6/7/8_3DM_file_format_to_Rhino5_3DM_file_format_(MOI3D_compatible)_converter
But I think that is only one part of the problem, you will still have the problem that an STL file only contains polygons in it and not structured CAD data like spheres, cylinders, and smooth surfaces.
There is some more info on polygon mesh data versus CAD model data here:
https://moi3d.com/faq#Q:_Why_can_I_export_to_.obj_format.2C_but_cannot_read_.obj_format_into_MoI.3F
Some recent discussion on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=12004.1
12039.3
Thanks Michael.
That's very useful to know. I did used to know this, but age, (and memory in particular) has got the better of me! :)
Best,
Tom
12039.4 In reply to 12039.2
Michael,
I tried to run the 3DM Rhino v6 to Rhino v5 converter, followed the prompt to execute the terminal command, but terminal just responded with this:
xattr: No such file: /Applications/Convert3DMToRhinoV5
Is this a security permissions problem as I then get a prompt to move the converter to the bin.
I could try running MacOS preferences and clear it manually?
Tom
12039.5 In reply to 12039.4
Hi Tom,
You would get this if you tried to run it directly from the Downloads folder.
After downloading it, drag it over into the /Applications folder, then give it another try.
