Boolean
11943.1
Hi
I have MOI 5.0 beta, and I'd like to know what I need to change in the "moi.ini" file so that it appears like this when I open a file.
Thank you for your help.
Seems this is sufficient ?
And it's automatically reccorded on the .ini
11943.3 In reply to 11943.1
Hi Booleano, is it that you want those styles to be the default ones when you first launch MOI or do a File > New ?
If so then set up the styles how you want them and then save that to a .3dm file and then put in that file as the template file in Options > General > "Template file:"
When a template file is set, the default styles will come from that file when you start up MOI or do a File > New.
11943.4 In reply to 11943.2
Thanks Pilou
11943.5 In reply to 11943.3
Thanks Michael
