Add "Make corner point" as a shortcut key?
11915.1
Hi guys, I use the "Make Corner Point" setting a lot and wanted to add it to a shortcut key. What should I be putting here as I can't figure it out. Many thanks!
11915.2 In reply to 11915.1
Press CTRL when you click a point ! You win a shortCut!
For avoid to recall the fonction Curve , enable repeat case...
For close the function press Right Click, Right Click again for recall the function if repeat is not enabled!
EDITED: 29 Jan by PILOU
11915.3 In reply to 11915.2
Oh my god! You sir are a legend! Thank you so much :)
11915.4 In reply to 11915.3
Many "hidden secrets" can be found at https://moi3d.com/4.0/docs/moi_command_reference.htm
Hope this helps.
Mik
11915.5 In reply to 11915.4
Thanks Mik, I'll check it out! :)
