Ways to rescue broken objects?
11903.1
Quite often after many boolean operations, objects become broken, in that they don't accept further boolean operations. (Sometimes objects also become "joined surfaces" instead of "solids", but that might have different causes.)
Usually at that point I just rebuild them from scratch. It's usually not too much work because I can use the broken object to snap to, but I'm wondering if maybe there is a faster way to repair such an object?
Like the one in the attached file. I was trying to cut out (boolean diff) the rectangle, but the object is done, it doesn't take any more boolean operations. Time for a rebuild I guess.
11903.2 In reply to 11903.1
Don't understand the problem of the rectangle ?
You have the Ctrl + z many time for take back error...
The only native function that I know for repair something is the erase Fillets selected function ! (Beta V5)
ShortCut : Right Click on the Red X (bottom bare line Delete)... the more easy to remember :)
Shift + Del Click or Shift + Click
EDITED: 14 Jan by PILOU
11903.3 In reply to 11903.1
Hi Andre, this can happen if there is a self intersection or degenerate faces. In your case here there are some faces that have all their surface area trimmed away so the entire surface looks like a line. I'll post more info and an updated model for you a bit later.
11903.4 In reply to 11903.3
So with the sliver surfaces the tricky part is to locate them. Then the fix is to delete them and then use Edit > Separate and Edit > Join to glue together all the other pieces.
11903.5 In reply to 11903.1
Hi Andre,
Here's a (mostly) repaired version that booleans with the rectangle ok.
The problem was that there were some really tiny edges and surfaces. Some of this junk was along the edge of the rectangle and so was confusing the boolean. I found the problems using this plugin:
https://moi3d.com/forum/lmessages.php?webtag=MOI&msg=11271.13
I then separated out the bad surfaces, trimmed off the junk, entirely remade the large cylindrical surfaces, and then joined everything back together. I left in some junk outside the area of the boolean. One problem is marked with a red point.
- Peer
11903.6 In reply to 11903.1
""""""""" It's usually not too much work because I can use the broken object to snap to,""""""""""""
Don't do that! What you want to do is alter your creation method to not create broken objects.
With Booleans, the "seam edges" of objects involved in the Boolean is most often the culprit. When you are making little cylinders to Boolean out a hole (Or using circles too), Make sure to rotate the seam edge OUT of the way, or farther away from other edges, to not create the little slivery result
11903.7 In reply to 11903.6
Here is a video of repairing your object. I dont think you really needed a repair video (Others may find it useful) Mostly I speed through to the end where I wanted to make the "SEAM EDGE" point I was talking about
Let me know if it is not clear
11903.8 In reply to 11903.7
I left out of the video, but its also relevant.
The seam edge that was "Close" should have attention still if you plan on "FILLETS"
A fillet running into a seam edge can have difficulties and fail...
So remember. "Seam edges!!!!
