voronoi 3D
All  1-3  4-9
1190.4 In reply to 1190.3
There are also prototype Rhino tools for Voronoi patterns (2D and 3D) which can be downloaded from the Rhino Labs page...
http://en.wiki.mcneel.com/default.aspx/McNeel/PointsetReconstruction.html
jonah
1190.5
1190.6 In reply to 1190.3
Hi Micheal,
I have installed the Rhino evalution, loaded down the script from here http://jeneratiff.com/doku.php?id=articles:voronoi_diagrams , copy and paste to a editor, did the file name .rvb, drop/draged it to the main window from Rhino and got the message unknown command.
Next try: I got the tip to delete all line numbers. I did it. I got the command: unknown command ´´
So I deleted all ´´ , next was unknown command: QVoronoi.
I don´t know what to do further and hope you can help me.
Regards RUdl
1190.7 In reply to 1190.6
Why don't you try the native Rhino "Lab" tools for creating Voronoi, mentioned in previous post # 1190.4. Unless there is something unique which this other script can do which Rhino's tools can not?
jonah
1190.8 In reply to 1190.6
Hi Rudl, have you been able to contact the author of the script? I think their e-mail address is listed on the page there - they would definitely know the most about it...
Since it is a Rhino script, you also might try asking on the Rhino newsgroup here
Let me know if none of the above helps any and I can try to take a look, but it will have to wait until after I return from vacation next week.
1190.9 In reply to 1190.6
Hi Rudl,
I have tried that script in Rhino V3 and V4 and it seems to work fine. Just download attached files and save them somewhere. Drag&drop a "qvoronoi.rvb" file into the Rhino. The open dialog window should appear. Select the output.txt file you downloaded before...
Petr
Show messages: All  1-3  4-9
