Is there a way to add textures to faces?
11852.1
Good day.
Is there a way to do this in Moi or other software...something like this?
https://www.youtube.com/shorts/A-7vmxC_gX8
Thanks!
11852.2 In reply to 11852.1
Hi Matadem,
The video is about how to do it using other software. The software is called "Preform".
Where the video describes to assign different colors to faces, you can do that in MoI by assigning the face to a different style color. Then export to .obj format and then inside preform you will be able to place different textures on faces that were assigned different styles.
There are some other programs that are focused on applying displacement textures like ZBrush or 3D Coat, you might want to look at those.
11852.3 In reply to 11852.1
You can also use the free powerful Vizcom!
Import your 3D file or any image of it!!!
And apply any texture you want! :)
And 10 times more easy than other classic prog! ;)
Moi
Vizcom and / or Nano Banana
EDITED: 3 Dec 2025 by PILOU
11852.5
The preform would be perfect If I can use it with my machine.
but after some testing it seems my best option is the use zsurf4.
just did a test and it was perfect for what I need this time.
Tnx!
Size: 43.1 KB, Downloaded: 37 times, Dimensions: 431x379px
