Helix rounded on average possible
Lara (MALA)
16 Oct 2025 (1 of 8)
11814.1
Hello, is it possible to make a helix with MOI that is rounded on average?
Helix Rounded.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
16 Oct 2025 (2 of 8)
11814.2
Here i take a diagonal of a rectangle
Then Flow it on any symmetric bowl ( because curriously project a curve don't works)
I had one turn!
So stack the bowls !
That must make the trick! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
16 Oct 2025 (3 of 8)
11814.3
In reply to
11814.1
Select curve and use the twist tool.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Lara (MALA)
16 Oct 2025 (4 of 8)
11814.4
In reply to
11814.2
Thx. But I cannot follow your workflow.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
16 Oct 2025 (5 of 8)
11814.5
In reply to
11814.1
see photo.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Oct 2025 (6 of 8)
11814.6
About my not speed method :)
Sorry in fact you don't stack the bowls but you trim it horizontally!
Then Flow the diagonal of the rectangle on each slice bowl part :)
Not the helix following!
EDITED: 16 Oct 2025 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Oct 2025 (7 of 8)
11814.7
In reply to
11814.1
Hi Mala, if you're still stuck you can also reference this previous discussion thread here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11777.1
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Lara (MALA)
17 Oct 2025 (8 of 8)
11814.8
In reply to
11814.7
Almost perfect for my effort, Michael. Thank you very much!
Also to all your other ideas !
Best, Mala
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
