V5 beta Sep-17-2025 available now
 1-20  21-40  41-60  …  101-104
Get it at:
https://moi3d.com/beta.htm
Will be working on full release notes a bit later, there are more functions integrated from the ACIS geometry kernel.
Selected faces can now be manipulated with the Transform > Move, Transform > Rotate and Transform > Rotate Axis
commands. This uses the ACIS direct model editing component to extend and intersect surrounding faces to
accommodate the change.
Enables dynamic editing of solids like this:
New RemoveAndFill command - use Shift+Delete keyboard shortcut or Shift+click or right click on Delete button to invoke ACIS Remove component that deletes faces and then heals the resulting openings by extending and intersecting surrounding faces:
ACIS Shell function is now used by the MoI Construct > Offset > Shell command.
Also lots of fixes for ACIS filleting.
EDITED: 27 Apr by MICHAEL GIBSON
11803.2 In reply to 11803.1
Happy New release!
11803.3 In reply to 11803.1
WOOOW, looks insane!
11803.4 In reply to 11803.1
Where is the download link? maybe I am too excited I cannot find it!
11803.5 In reply to 11803.4
Oops sorry! Here:
11803.6 In reply to 11803.4
Thank you Michael !
Great additions !
In the "remove fillets" video, you seem to remove the fillets by selecting adjacent faces.
When trying it, it works when I select only the fillets to be removed. This is OK ?
Edit
Oups, I carefully watched the video again and you then inversed the selection to get the fillets selected before deleting them.
Also, it is interesting to note that moving a face(s) over holes will "erase" them.
When extending the face again, we have a clean surface.
It can be a fast way to delete many holes at once.
Edit 2025-09-22
Moving holes works with solids.
Could it eventually also move holes on a plane or is it restricted to 3D solids by the ACIS library ?
As a workaround, I extrude the pierced plane, transform it then delete the volume faces to keep only the top one. Not very time consuming in fact.
EDITED: 22 Sep 2025 by VINC
11803.7 In reply to 11803.6
Great improvements! Thanks, these updates are pretty useful.
11803.8 In reply to 11803.6
Hi Mip,
I used a "Invert selection" shortcut key to switch selection onto the fillets after selecting the larger faces.
Sometimes it is easier to select the pieces you want to keep and then invert.
If you want to set up a keyboard shortcut for invert selection, put this on a shortcut key:
script: moi.geometryDatabase.invertSelection();
(EDIT: looks like you figured that out already)
Yes, it will be interesting to see how it behaves when pieces bunch up.
Another thing that I want to set up for a circular hole to be able to change its radius.
11803.9
Question will be scaling of the holes be possible? same as moving them around?
Tnx!
Remark that the "Remove Fillets" Remove also "Chamfers" ! ;)
My Moi French Site
11803.11 In reply to 11803.9
Hi Matadem,
Yes I think I will be able to do that. Probably if cylindrical faces or circular edges are selected then
the current radius or diameter will be shown here and then click on that to change it:
There is actually a display and edit menu there since version 2 I think but it scales the entire object instead of modifying just the hole.
And what about Move Copy, Rotate Copy ?
My Moi French Site
11803.13 In reply to 11803.12
It looks like there's a bug with Rotate copy, it was intended to retain the previous version behavior there. I'll see about fixing that.
11803.14
Looking good Michael, thanks for all your work on this.
3D Hard Surface
mbt3d.com Artstation
11803.15
Impressive!!!!
Works fine...
My Moi French Site
11803.17 In reply to 11803.16
Wow cool features :)
Thanks Mickael
11803.18
Wow, this opens up whole new ways for constructing objects !
I’m looking to explore and integrate these features.
I appreciate your patience and dedication to bringing your vision to life.
Moi's focused interface is truly impressive.
Marc
11803.19 In reply to 11803.1
OMG
MoI became magical...
Thank you Michael!
I wanted to test moving holes on curved surfaces. It seems to work when cutting the hole in formed solids.
If I create a curved surface, "trim the hole" then shell for thickness, the Move produces an artifact in the hole (For me. Lets see if its reproducible)....
Here is a file
Show messages:  1-20  21-40  41-60  61-80  …  101-104
