How to trim allot of pieces fast?
11785.1
Good day.
How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
also thinking on this maybe in the future to get selection tools...like lasso , circular?
Tnx!
Size: 104.7 KB, Downloaded: 58 times, Dimensions: 649x573px
In your special case
Maybe you have better time to make one losange module
then make an Radial Array
All makes maybe 2 seconds! :)
PS You must also put your object on the origin and not in the empty space of the galaxy! :)
Because some functions don't like this sort of thing!
11785.3 In reply to 11785.1
Here is one....
11785.4 In reply to 11785.3
Then using a surface and Boolean to generate the edges needed....
11785.5 In reply to 11785.1
Hi Matadem,
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
11785.6 In reply to 11785.5
Or "Union" gives you the opposite side...
11785.7
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
