UI Layout
11765.1
A few days ago i setup a new pc. Istalled Moi. And after installation, i copied the complete moi-folder from my old pc to my new one. I thought I get the same settnings and everything as i used on my old pc. It worked so far, but the layout didn't and the scripts.
I can't remember how i've made it on my old pc.
11765.2 In reply to 11765.1
Hi B-W-Design, sorry I'm not understanding what you mean by "the layout" ?
Can you maybe describe that part a little bit more?
11765.3
Hi Micheal, at the bottom of the window i got some align-tools. and two icons for some scripts. It's a real big bunche of scrpits. But after a fresh installation of moi i don't figure it out how i have done that in the past.
11765.4 In reply to 11765.3
Hi B-W-Design, are you on Mac or Windows?
Also which version of MoI are you running?
11765.5
Windows, latest Beta
11765.6 In reply to 11765.5
On your old machine, tap the Window key and put in:
%appdata%\Moi\startup
Are there a bunch of files in there?
11765.7
Yes, there are some files in it. The second one is in the folder.
11765.8
on my new machine, there is nothing, or, it dosen't show any folder
11765.9 In reply to 11765.7
If you go to %appdata%\Moi\startup on your new machine, is it empty or do you have those files copied over?
11765.10
It's empty. It dosen't show up anything. No folder, do files.
11765.11 In reply to 11765.8
What was the moi-folder you copied, was it in c:\Program Files ?
If so then in addition to that you need to copy %appdata%\Moi including all sub-folders within it over to the new machine too.
11765.12
Ah, only copied c:\Program Files
Wait a sec. I will try to copy the other folder too
11765.13
Ohhhhh, this is so awesome!! It works.
Thank you so much for your quick help!!!
Janne
11765.14 In reply to 11765.13
Hi Janne, that's great, you're welcome!
