Confirm/Abort Dialog Box
11715.1
Is there a standard dialog that can be displayed prior to execution of a potentially very disruptive operation that can ask the user to confirm execution or allow canceling?
Thanks.
Frederick
11715.2 In reply to 11715.1
Hi Frederick,
There is not - things like that are usually generated internally by the GeometryFactory infrastructure in a separate process called moi_commandprocessor.exe instead of the main UI thread so that the cancel button in the UI remains responsive and clickable.
But that infrastructure is part of the internal C++ API, it isn't accessible by the script API.
If you have a long running script there is a mechanism that will try to exit it if you hold down the Esc key.
11715.3 In reply to 11715.2
Could you add a script function to V5 that could display a dialog asking for confirmation and simply return true or false?
Frederick
11715.4 In reply to 11715.2
Hi again,
While I'm here I thought you might like to see what your recent help has led to.
I've got a minor tweak or two I'm thinking about but they all are meeting my needs right now.
Thanks for everything.
Frederick
11715.5 In reply to 11715.3
Hi Frederick,
You can make a dialog like that in a plug-in, see attached example.
Great, I'm glad it's useful!
Thanks, - Michael
11715.6 In reply to 11715.5
I tried out your example with the "confirmation dialog" - it is just what I was envisioning.
Perfect.
Another tool for my toolbox.
Thanks.
Frederick
