When looking at a line running parallel to the X axis, from a front/back view, you can tell when it is selected, as the yellow highlight color appears.
When look at the same line, from a left/right view, you can still tell when it is selected, if you look closely, as the yellow highlight color appears (as a dot) and the square bracket symbols are visible.
But when looking a a plane parallel to the XY plane, from a front/back/left/right view, you can see the "edge" of the plane BUT the yellow highlight does not appear when you select the plane. When selected, you still see the two square bracket symbols but they are easy to miss.
Not a big deal - perhaps it works this way (no yellow highlight) for a reason.
Just FYI.
Frederick
