Screw Cap Container
11629.1
Hi All,
I'm trying to design a functional small screw cap container:
I started with a helix and then created a triangular profile which I intend to rail revolve using the helix as the rail. Problem is when I do that, the rail revolve just makes one circle and does not follow the helix:
Could someone let me know what I'm doing wrong?
Also, I'll need to create the screw cap which I assume will be by using the boolean difference command. What would be the approximate tolerance I should use for a functional screw cap?
Many thanks in advance!
Gunter
11629.2 In reply to 11629.1
There is a NutsAndBolds script.
11629.3
Select the profile, click Construct-Sweep and select the Helix Rail. Select both solids and click Construct-Boolean Union. Draw a horizontal line at the top of the jar and click Boolean Merge to trim.
11629.4 In reply to 11629.1
11629.5 In reply to 11629.4
Thank you Michael!
Gunter
11629.6 In reply to 11629.3
Thank you dansperk!
Gunter
11629.7 In reply to 11629.4
Hey Michael,
When I sweep the thread profile along the helix, I notice the profile of the thread seems to change as it goes down the z axis:
No idea why it does this and how to resolve it?
Many thanks!
Gunter
11629.8 In reply to 11629.7
Hi Gunter, you need to set the "Twist = Flat" option in the sweep options:
11629.9 In reply to 11629.7
Hi Gunter
If you copy your spiral rail downwards so there are 2 and do a 2 rail sweep of the thread profile.
This will stop it from deforming
cheers
shayne
11629.10 In reply to 11629.8
Great, thank you Michael!
Gunter
11629.11 In reply to 11629.9
Thank you Shayne!
Gunter
