Is STEP import coming?
All  1-3  4-7
1161.4 In reply to 1161.3
cool trick ;)
1161.5 In reply to 1161.3
I downloaded and installed the iges2step software but it crashes on startup with the message "Fatal Error in units initialisation". I noticed its copyright is from 2003. Maybe there is problem with newer versions of the Microsoft Visual C++ Runtime like the 2005 one installed on my Windows XP Pro laptop.
Al Greynolds
www.ruda.com
1161.6 In reply to 1161.5
Hi Al, I took a quick look and saw the same problem. The fix is to reboot your machine, it should then work after you have rebooted.
It needs a couple of environment variables set to work properly, on install the changes to the environment variables don't quite spread out to the entire system, but they will after a reboot.
It's interesting - appears to be based off of the Open CASCADE kernel. It's actually parts of Open CASCADE that need the environment variables set.
1161.7 In reply to 1161.6
That worked. Thanks Michael.
Al
Show messages: All  1-3  4-7
