Hi Vic,
First, thank you for the theme examples & the concise installation notes.
However, may I humbly suggest that you consider removing the leading dash "-" from the filenames please? If a separator is important to you, perhaps use underscore "_" instead? My rationale is that the UNIX shell utilities take the dash as a command modifier thus a command like:
% unzip -l -Dark 008_Black\ Charcoal_Highlight\ Orange.zip
does not work because unzip doesn't understand "-D". Sure I know in this day and age everyone just clicks madly but for those of us who prefer to inspect what it is that we've just downloaded before using it, little things like filename conventions do matter.
While I'm nit-picking, you also may wish to exclude the macOS dot files & directories from your archive as they're not necessary for MoI:
% unzip -l Default\ 03_Off_White_Classic\ Background.zip
Archive: Default 03_Off_White_Classic Background.zip
Length Date Time Name
0 05-23-2023 11:08 -Default 03_Off_White_Classic Background/
6148 05-23-2023 11:08 -Default 03_Off_White_Classic Background/.DS_Store
120 12-14-2024 10:29 __MACOSX/-Default 03_Off_White_Classic Background/._.DS_Store
4096 09-20-2024 10:35 -Default 03_Off_White_Classic Background/._.DS_Store
191 09-24-2022 13:21 -Default 03_Off_White_Classic Background/moi.css
6615 02-22-2024 11:42 -Default 03_Off_White_Classic Background/defines.inc
1881 10-13-2022 17:36 -Default 03_Off_White_Classic Background/Point.png
176 12-14-2024 10:29 __MACOSX/-Default 03_Off_White_Classic Background/._Point.png
4096 09-20-2024 10:35 -Default 03_Off_White_Classic Background/._Point.png
23323 9 files
--Larry
