Hi Joerg,
> For most parameter/options this works very well, but there is no parameter for the
> dimension/annotation color available. You only can change the color after you
> created a dimension.
When you create a dimension it will be assigned to the "active style". The active style is marked in the Scene browser with an extra ring around its color swatch. It can be set by a right click on the swatch.
For example here the active style is set to Green:
If you then draw a dimension with the active style set to green, it will be green.
That's the same for drawing lines, circles, spheres, etc...
But I'll see about adding in an option for putting dimensions on their own style instead of on the active style.
> @Michael Gibson, Maybe you can have a look for the parameter "Mesh Angle". This one is
> always set to 10 after starting MoI and it is independant from what is defined in the moi.ini file.
> I recognized that because when checking the smoothness of surfaces or curves, I always set
> the mesh angle to 1 (°).
Some info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11134.5
