I have some curve segments joined up as a closed curve. The fillet tool finds the sharp corners of the curve, but it fails to calculate the fillet. The curves which meet at sharp cusps all lie on the surface of a solid (though things seem to have become slightly inaccurate as it's gotten more complex).
Is there a way I can simplify the curves, assuming that's what's causing the issue? Or should I find a workaround such as trimming back the segments near the desired fillet, and using the blend tool? Perhaps the fillet tool only operates on coplanar segments?
Thanks!
