How to make frosting on a donut?
11522.1
Hey folks. So I have my donut as one object, and my frosting as another.
How can I "drape" the frosting over the donut? I normally design machinery and hard surfaces, not something like this, so I'm at a loss.
Thanks!
Chris
11522.2 In reply to 11522.1
Try the native Transform / Deform / Flow function! ;)
Bon appetit!
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
PS Not exatly that you want but for the fun you have a cloth simulation by Max Smirnov
https://moi3d.com/download/scripts/max/Cloth.v.0.97.2017.11.23.zip
EDITED: 30 Aug 2024 by PILOU
11522.3
I would copy your donut, cut down to where your bottom drip will be (straight line) separate the top surface and shell it to make it a solid. then cut the wiggly lines on it by creating boolen operation with a separate object.
11522.4 In reply to 11522.1
Hi Chris, it's possible to use Transform >Deform > Flow to do this but it will be a bit tricky. The donut would need to be rebuilt to be just a single surface revolved from a curve with just one segment in it and the base surface would need to be a revolved plane instead of a regular 4 corner point plane.
Instead it might be easier to create some cutting surfaces to cut the donut up and shell the remaining piece to thicken it.
11522.5 In reply to 11522.1
Something like this -
Loft a cutting surface between 2 curves for the outside:
Loft a similar cutting surface for the inside:
Use Edit > Trim to cut the donut with those lofted surfaces as the cutting objects.
That will make a result like this which you can thicken using Construct > Shell :
11522.6 In reply to 11522.5
Well that was unpleasant. Thank you everyone for your help!
Chris
