Boolean Difference won't work.
11519.1
Hello All,
I'm having some really odd issues. The attached file is the outline for a Star Trek Federation Starship's B-C Deck, that's the raised structure just below the actual bridge. I've swept the basic shape, then shown points and pushed-pulled the observation area in the back into position. Now, I'd like to Boolean Difference using the rectangle there as the cutting surface or plane, removing part of the B-C Deck. Afterwards, I'd like to mirror what's left to its symmetrical, then create a solid from it. However, MOI won't let me Boolean it. The Boolean Difference command simply won't work. I've also tried using a solid as the cutter to remove, and the same thing happens. I suspect I'm doing something SUPER BASIC wrong, and I'm just too dense to see what's right in front of me. Any ideas?
Many thanks,
Bob
EDITED: 23 Nov 2024 by APTIVABOY
11519.2 In reply to 11519.1
Make a big box (top & bottomdown) from your rectangle
kill or hide all curves
Boolean Diff
Kill the rest
EDITED: 18 Aug 2024 by PILOU
11519.3 In reply to 11519.2
That wouldn't work, either. I tried solids, but no go. I was finally able to get it to work by Boolean Differencing each individual panel or surface, one after the other. Ugh... Thank you for the idea, though!
Bob
11519.4 In reply to 11519.1
Hi Bob, I think the part where the booleans try to intersect the pieces is getting confused with there already being a cut through that same spot.
Instead of doing a boolean in this case you can select these faces and delete:
