Hi stefano, yeah it can be hard to read ones that have been condensed to one line for shortcut key pasting.
Here it's separated out:
moi.copyTextToClipboard( moi.geometryDatabase.notes );
var factory = moi.command.createFactory( 'annotationtext' );
factory.setInput( 0, moi.vectorMath.createTopFrame() ); <<<<<<<<<<<<<<<<
factory.setInput( 1, moi.geometryDatabase.notes );
factory.setInput( 2, 0 ); factory.update(); // Index of annotation property preset to use, 0 = "Default" preset values used.
var objs = factory.getCreatedObjects();
objs.setProperty( 'hidden', true );
objs.setProperty( 'name', 'Notes' );
factory.commit();
The line marked with <<<<<< is the one that sets the position.
moi.vectorMath.createTopFrame() will generate a coordinate frame object (made up of an origin point, and vectors for x,y,z axis directions) with world aligned x,y,z axes and origin at 0,0,0 by default.
If you wanted it to go at x=10, y=5 you could do it like this:
var frame = moi.vectorMath.createTopFrame();
frame.origin.x = 10;
frame.origin.y = 5;
factory.setInput( 0, frame );
