Can the exported SVG output be setup by the user to omit the VISIBLE LINES and just output the user-selected line option(s)... which for me would be 'Generate outlines' to support my laser cutting workflow?
If not, could VISIBLE LINES be added to the selectable line types so the user has the option to omit?
I often use 2D outlines from my MOI3d (Dec 2023 beta) designs to laser cut materials. The laser does correctly recognize and cut the unjoined curves, but the laser path is often not optimum since the laser sees individual curves and not a closed curve that can be followed from start to finish. So my best solution to date has been to individually identify and select the individual VISIBLE LINES to either (1) join the curves or (2) delete the curves and use the 'Generate outlines' option which has these individual curves already joined. This process can be time consuming for complex designs with multiple closed curves on a single 2D view.
Thanks as always for this wonderful CAD program! Always fun to use.
Scott
PS --
For SVG export, could you please explain the line "Width' setting on the 'Line style option' page?
By trial and error, I've been able to use in my MOI3d SVG exports a line width of 0.2 to give me a AFD 0.003 inch line width, but I have no idea how the 0.2 value correlates to the AFD 0.003 inches?
My MOI3d SVG export settings for units are
--Scale: preserve units
-- 1 units in MOI = 1 mm on page
-- My page size is 'custom w 24 x h 12 inches'.
