Hi Mindset,
> The edit affected the entire group, including hidden objects!
Yes, that's the intended behavior, if you have a group selected then an edit works on the whole group including hidden sub objects.
That's the same behavior as other programs that use groups, like Affinity Designer or Inkscape for example.
> Might that behavior be configurable to either generate a warning or to
> safeguard hidden objects from edits altogether?
I'm sorry but it would become difficult to test things if there were settings that changed this type of behavior.
Are there other programs that you're using that support a grouping function that has settings or warnings for this?
> Might it be possible to augment array commands to accumulate resulting groups, rather
> than creating a multiplicity of groups?
It's also the intended behavior that copying a group object results in another separate group object and not a merged group.
But instead of using groups you can use object names which will behave like you're asking.
For example if you have multiple objects with the same name assigned, there will be one entry for them in the "Objects" section of the scene browser, and any that are hidden will not be targeted for an edit command and if you array them the copied objects will have the same name as the input objects and so will be controlled by that same scene browser entry as well.
