Hi Gunter, yes like Pilou writes above it's likely that the .3dm file only contains polygon mesh type objects and not NURBS surface type objects.
Typically that type of data can't be imported into MoI because it's made up of a lot of little flat polygons instead of structured CAD surfaces which MoI is focused on using.
You can export from MoI into a polygon mesh program. When you do that MoI will chop up the model into little polygon pieces. But it isn't easy to go the reverse direction.
So except for in some special cases usually it's a one way data transfer out to ZBrush.
