edge blending
All  1-7  8-9
1147.8 In reply to 1147.7
Nurbs are tricky things isn't it? :)
1147.9 In reply to 1147.7
You're welcome Lemo!
There can be many situations where it can be easier (and produce more reliable geometry), to kind of imagine a larger extended surface that gets trimmed back to make your final shape, rather than trying to create a surface only by following outline curves.
If your outline curves have a very natural 4-sided type layout, then surfacing them directly is fine, but otherwise building extended and trimmed back can be better.
Here's another example from a recent thread: http://moi3d.com/forum/index.php?webtag=MOI&msg=1127.4
In that case it helped to build a single larger slightly curved surface as the cap of the object which then gets trimmed, rather than trying to sweep using the existing outline curves which came to a kind of difficult corner which caused a sort of bunching and overlapping of the surface when trying to sweep.
Show messages: All  1-7  8-9
