Filleting solid issue
gunter511
7 Jul 2024 (1 of 5)
11465.1
Hi All,
The top edge marked with the red arrow is easily filleted by click on it but the yellow edge of the ring can't be filleted:
Could someone please explain why? I made sure the object is booleaned and is a solid.
Many thanks,
Gunter
EDITED: 15 Jul 2024 by GUNTER511
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
7 Jul 2024 (2 of 5)
11465.2
In reply to
11465.1
Surely because it's too large take a smaller one! ;)
As we can see on the top image there was calculated ...but overlap...existing solid...
so a smaller one will be fine!
Sometime when faces created overpass the solid you can make a Boolean Diff !
In any case in this sort of object make the fillets one by one it's more prudent!
PS post the object is also a good thing! ;)
EDITED: 7 Jul 2024 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
gunter511
7 Jul 2024 (3 of 5)
11465.3
In reply to
11465.2
Hey Pilou, thanks I tried a minimum of 0.5mm which WAS too large! 0.1 worked!
And sorry, I didn't post the file, I normally do :)
Much appreciated, and on a Sunday too!
Gunter
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
7 Jul 2024 (4 of 5)
11465.4
In reply to
11465.3
If the fillet fails like that...you can use the surface for a Boolean Diff! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
gunter511
8 Jul 2024 (5 of 5)
11465.5
In reply to
11465.4
Great, thank you Pilou, appreciate all you help!
GUnter
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
