Filetting Filigree
11458.1
Hey All,
Here's the design:
I'd like to round off or fillet the top sections of the patterns and have tried selecting edges and surfaces, but haven't been successful.
Could someone please explain how I can achieve this?
Many thanks in advance.
Gunter
EDITED: 18 Jul 2024 by GUNTER511
11458.2 In reply to 11458.1
For this sort of thing
Better to seperate all forms!
And not use mm !
Here i scale by 100
Use no unities
Acis don't works!
Only Solids ++
Max fillet is here 0.4 (depending of the admissible max along the top face perimeter!
11458.3 In reply to 11458.2
Thank you Pilou, separating forms is no problem. The issue is I'd like to have the solid patterns rounded at the top and not just a small fillet along the edges.
Like this:
How would I go about doing that?
Many thanks,
Gunter
EDITED: 15 Jul 2024 by GUNTER511
11458.4 In reply to 11458.3
Hi Gunter,
Is this for 3D printing, for CNC milling, or for rendering?
- Peer
When you draw with less sharp angles you can increase the fillet!
Here 4 max 4 for example so x 10 from above
Don't seen your last example! :)
11458.6 In reply to 11458.4
Hi Peer,
It's for 3D resin printing.
Gunter
With your last example
I believe that you must make some lofts so some sections! ;)
Or some ideas by Barry H
http://moi3d.com/forum/index.php?webtag=MOI&msg=11206.1
EDITED: 3 Jul 2024 by PILOU
Or some subdivisions... ? :)
Look at this bible thread of subdivide in MOi! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
11458.9 In reply to 11458.6
Hi Gunter,
Since this is for 3D printing you are almost certainly better off using a different type of software like ZBrush. Here's a tutorial on filigree.
https://www.youtube.com/watch?v=n6TVd7vZSII
Making filigree in MoI, or any other NURBS CAD software, would be quite challenging and time consuming. The only reason I can imagine doing that would be if the part needed to be milled.
- Peer
11458.10 In reply to 11458.3
Hi Gunter, yes like Peer writes above it will be difficult to make an organic form like you want in a CAD program where the focus is more on mechanical parts.
You may want to check out 3D Coat in addition to ZBrush for making that type of model.
