一个独立的视口截图工具取自M3DCH UI(An independent viewport screenshot tool taken from M3DCH UI)
11448.1
Hello EveryOne
我昨天在寻找一个能在moi中快捷调用的截图工具,我使用过论坛中的代码(I was looking for a screenshot tool that can be quickly called in Moi yesterday, and I have used the code from the forum before)
script: var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0xFFFFFF; moi.view.lineWidth = 4; moi.grid.display = false; moi.grid.showXYAxes = false; moi.view.showAxisIcon = false; moi.view.showViewTitles = false; var img = null; try { img = moi.ui.getActiveViewport().render( 4000, 2500 ); } catch(e){} moi.view.lineWidth = 1; moi.grid.display = true; moi.grid.showXYAxes = true; moi.view.showAxisIcon = true; moi.view.showViewTitles = true; moi.view.viewportBackgroundColor = prev_background; var name = img.getSaveFileName(); if ( name != '' ) img.save( name );
但效果并不好,运行它会更改我原本对视口的设置,无法截取同时显示四个视图的快照也会强制更改设置,显示参考网格。我短暂的使用过M3DCH 这套UI,在它的插件中找到了这个插件,这是我的使用效果图:
(But the effect is not good. Running it will change my original settings for the viewport, and I won't be able to take a snapshot that displays all four views at the same time. It will also force me to change the settings and display the reference grid. I have briefly used the M3DCH UI and found this plugin in its plugins. Here is my usage rendering:)
看得出来,无论是在怎样的视口和材质情况下,快照效果都不错。可以设置快捷键A 值=ScreenCapture(或任何你重命名ScreenCapture.js的对应名称 )
(It can be seen that the snapshot effect is good regardless of the viewport and material conditions. You can set the shortcut key A value to ScreenCapture (or any corresponding name for renaming ScreenCapture.js))
希望后续版本默认添加这个脚本(hope that future versions will add this script by default)
11448.2 In reply to 11448.1
This one lets you set resolution to whatever your video card will pump out. I dont remember whether it does all 4 views at once or only active, but it wont change settings
It saves to clipboard so you can paste it where ever to create any image type
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=1049.5
There is also a “screen grab” type one that will just save a file for you. On petr’s MoI page. I’ll get a link then edit that in here in a second.
Here:
http://kyticka.webzdarma.cz/3d/moi/#CaptureScreenToFile
11448.3 In reply to 11448.2
HI BurrMan
这太棒了,但我认为制作成可调用的js脚本而不是使用代码调用的意义:
(This is great, but I think the significance of making it a callable JavaScript script instead of using code calls is:)
就是人们不再需要记忆、理解长长的代码,而使用自身文字来定义快捷键,我想这对一些人会很重要(It means that people no longer need to remember and understand long codes, but use their own language to define shortcut keys, which I think will be important for some people)
11448.4 In reply to 11448.3
Hi Suiyan,
So you can do it either way
If you have “inline” code, you can just add it to a text file with a “.js” extension. Then the command is whatever you name it.
So from your screenshot, “alt-s” then for the command put the name of your new js file (that you added to the command or scripts folder in your install directory)
11448.5 In reply to 11448.4
Thanks BurrMan,我才想到这么做(Thanks BurrMan, I just thought of doing this)
