Hi gunter,
> As you can see, the lattice work is stretched and the so the diamond shapes are stretched too.
> How would I go about making the curvature length the same but keeping the lattice unstretched?
You've got to be careful about where you click with the mouse on both the base surface and the target surface.
The stretched result is due to having this short edge:
Being mapped tot his long edge:
Instead you want the flow to match the short edge on the base to the short edge on the target:
The matching is determined by the pick point on each surface when you select it. You need to pick the point along each edge but a little ways in from the corner point. Don't pick right at the corner because it will take the closest edge to your pick and right on the corner does not control which edge is closest very well.
But also don't click right in the middle of the edge either because the closest end of the edge to your pick is also significant for matching the start or end of the edge to each other.
So you want to pick like this, on the edge, not too far away from the corner but not right at the corner:
And on the target surface like this:
