Hi Ray,
> When shortcut keys need to be programmed to remember when you need them, it is very frustrating.
You could solve this frustration by doing something as simple as recording what shortcut keys you have added in a text file and looking at it when you encounter this.
Another solution is you could install the CustomUI mod, which you can download from here:
https://moi3d.com/download/scripts/max/CustomUI.2.0.beta2.zip
Install instructions here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
That will add a "Scripts" button in the UI on the bottom toolbar that will show a menu with all added scripts on it. So you can then trigger a script by using the menu list instead of by shortcut key.
> Will the next update of 3D moi do something more reliable and not frustrate users
> with script commands they have to remember?
Sorry no it's not a priority since there are already existing solutions.
Let me know if you have any difficulty installing the scripts button. It's just a matter of copying files into the startup folder but I can walk you through it. Just let me know what operating system you are using.
