Trim at curve crossing
11423.1
I'm looking for a way to trim a first curve with a second cutter curve, but only where the first curve actually crosses the cutter and not where it just grazes it.
Like for a line tangent to a circle with the circle as the cutter the line shouldn't get cut at all.
But if the line passes through the center of the circle cutter then I expect the line to get cut into 3 pieces.
- Peer
11423.2 In reply to 11423.1
Hi Peer, there isn't anything built in to the regular Trim that would do that. I'd think you would need a custom made function.
First you'd need to get the intersections between the curves which you can do with the intersect factory:
var curves = moi.geometryDatabase.getSelectedObjects();
if ( curves.length == 2 )
    var curve_list = moi.geometryDatabase.createObjectList();
    var factory = moi.command.createFactory( 'intersect' );
    factory.setInput( 0, curves );
     var points_list = factory.calculate().getPoints();
     factory.cancel();
     var text = points_list.length + ' points\n';
     for ( var i = 0; i < points_list.length; ++i )
        var pt_obj = points_list.item(i);
        text += pt_obj.pt.x.toFixed(2) + ', ' + pt_obj.pt.y.toFixed(2) + ', ' + pt_obj.pt.z.toFixed(2) + '\n';
    moi.ui.alert( text );
Then for every point get a curve parameter value for the point with
var t = crv.dropPoint( pt );
Then you can evaluate the tangents of both curves using
var tangent = crv.evaluateTangent( t );
If the angle between the tangents is close to 0 or close to 180 degrees then it's one of the grazing intersections so skip it.
Otherwise keep it as a cutting parameter value, sort those cut parameters and then go through them generating pieces using:
var piece = crv.trim( paramA, paramB );
If it's a closed curve and you don't have the start/end of the curve as a cutting parameter then you probably want to call
var reseamed_crv = crv.changeClosedCurveSeam( t );
11423.3 In reply to 11423.2
Thanks for the rapid reply and thorough explanation!
I had no idea that curve.trim() was a thing, so that's pretty cool to learn about and it lead me to some other new curve methods.
I'll try coding up your approach.
- Peer
11423.4 In reply to 11423.3
Hi Peer, I'll also add in a curve.split(); method that will take an array of parameters, and it will handle changing the seam point on a closed curve.
11423.5 In reply to 11423.4
Nice! I'm looking forward to it Michael.
- Peer
