Text search
11411.1
Hello everyone. I do not know if such a question was asked here or not, but is it possible to implement a text search when selecting all annotations?
11411.2 In reply to 11411.1
Hi Brainfox90,
What are you trying to do? Replace some text? Only select annotations that contain a given string? Something else?
- Peer
11411.3 In reply to 11411.1
Hi Brian, can you please make an example 3DM file with annotations that you would want the search to find?
11411.4
I have a working file, and I need to change all the numbers, for example, 6.15 to 6.20, for this I need to find them in the entire file. Now this is done only manually. And I would like all the annotations to stand out according to the content
Size: 105.8 KB, Downloaded: 63 times, Dimensions: 1824x1096px
Size: 88.9 KB, Downloaded: 47 times, Dimensions: 1570x573px
11411.5 In reply to 11411.4
Hi Brian, can you please post an example .3dm model file with some annotations that you'd like to change so I can test with it?
Also I'm not understanding this part, could you maybe describe this a bit more? :
    "And I would like all the annotations to stand out according to the content"
11411.6 In reply to 11411.5
Hi Michael. I wrote an email.
11411.7 In reply to 11411.6
Hi Brian, thanks for sending the example.
Please try the attached script, is it close to what you need?
Instructions for installing a plug-in script are here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
11411.8 In reply to 11411.7
Thank you so much, Michael. You saved me!!!!
