Shield by Step3D
All  1-9  10-18
114.10 In reply to 114.9
> And for the grid it's my fault ! Your prog is so fluent than we
> don't think to go to press the menus :)
:) It seems that a lot of people don't find it.
I originally had the idea to try and put settings nearby the UI that is related to them (such as grid snap for grid), kind of in smaller bites instead of all in one big box. But that idea hasn't really worked out, it's just easier to find options if they are all in one spot.
114.11 In reply to 114.10
Yes because "Option enable" and "Menu" on the same plan when you press the little black triangle
can be pertubating :)
By Steph 3D
Some complaint by Steph
Possibility to group Objects ---> so export import moi export import moi etc = some hard method :)
Layers again
An automatic save increase name method file_01, file_02, file_03 etc
A speedy key for repeat the last function
114.14 In reply to 114.13
Wow! Really amazing detail! It kind of reminds me of some of the detailed French antiques that I have seen.
> Layers again
Yeah, I know that having these missing is painful for detailed scenes right now. But it is going to be a little while before this stuff is available though, I'm not really sure when yet.
I should be able to add a script method so that this could be assigned to a shortcut key, would that work?
This is ready for the next beta - you'll be able to right-click in a viewport to repeat the last command, and it will also be possible to assign it to a shortcut key.
114.15 In reply to 114.14
First of all, very nice work from Steph3D ! I know the guy from other forums and he's very talented !
Now a few comments or thoughts about the feature request...
- "Bi Offset" for sure ! but for me the user must have the choice to delete or not the original curve.
- Fillet on curve made of multiple segments : excellent option ! Good to see it will be in MoI very soon !
- Illustrator export. Yes !!! But Illustrator import would be great too ! I very often create complex shapes with the pathfinder in Illustrator. Also, this would allow to easily import text !
- Hotkey for last action repeat. If I understand well, not a hotkey that just recalls the last used tool but one that executes the last command again with the same values. Would be great with "make copies" activated to easily duplicate or rotate objects.
To this I would add :
- Reference images (independant in the various viewports)
- Array functions (already mentioned elsewhere) (on curve, circular, rectangular...)
- Project curve on surface
- Snap options on surfaces or polysurfaces
- Distortion tools (Twist, Bend, Shear)
... (to be continued) ;-)
Err... Forgot Spiral and Helix tools... ;-)
114.17
Michael,
I've seen incremental saves done with a '+' button in the 'save as' pop out.
Very neat and useable, like that, imho.
The video bug of Cube Filet by Steph 3D
http://www.zbrush.fr/phpBB2//download.php?id=996
690 kb Avi compressed (maybe same codec like above :)
Show messages: All  1-9  10-18
