Hot keys
 1-19  20-23
1139.20 In reply to 1139.19
I am hoping you will add "Incremental Save" as an alternative in the Save Icon on the desktop---please!
1139.21 In reply to 1139.20
Hi Brian, it is kind of tough to add too many things across there because it is a pretty tight fit on a 1024x768 screen.
But it is possible to edit the UI and add that button in there now if you want.
The file that controls that bottom toolbar UI is here:
C:\Program Files\MoI beta Nov-18-2007\ui\CommandBar.htm
You can edit that file with notepad to add buttons to the UI.
I've attached an edited version here that adds an "Inc" button next to Save, to do an incremental save. Unzip it, and copy this new CommandBar.htm over top of the old in in that \ui folder.
You'll need to repeat this in future installs though, so you may want to keep a note of this procedure.
1139.22
Hi, all
Thought I'd throw in my 2 cents,
I've been using an added tab for extra command buttons at the bottom of the side pane for a few months, so I thought I'd throw this out there, maybe someone will find it useful --
Instructions and files to set it up are in the zip. Hope this helps!
Paul
1139.23
Thanks Michael/Paul. I hope I can work out howto!---more learning..............
Show messages:  1-19  20-23
