You'd need to have side curves like this if you want to make it out of one sweep or network surface:
When sweep generates a surface, it calculates a profile at each position along the side rail curves. When you have 2 different profiles each touching the rail at the same position it doesn't know which one should be used at that spot, so you can't really set up a sweep in that manner.
