wishes...
 1-11  12-31  32-42
1131.12 In reply to 1131.11
Spot on Micheal,
Yes features are a collection from softwares that I have used and I fund them necessary for architecture and product design projects.
SolidWorks User since 2000, feels like yesterday.
But the good news 3 of us join forces to set a new design studio, so we looking at new tools .
We will be focusing on Concept and Viz of projects and outsourcing engineering...
Rhino is a very strong candidate(extensive Import/Export capabilities).
But as I mention before Moi is Fresh, Addictive, Original in Concept, and most important your knowledge and support, Priceless.
thanks
1131.13 In reply to 1131.12
Hi yannada, congratulations on starting your new design studio, that is cool!
re: your wishlist - I guess the question I have is, what if I did implement all the items on your wishlist so that MoI behaved the same as SolidWorks. What would the benefit be to you? I mean, can't you already use SolidWorks to perform all the operations that SolidWorks does?
1131.14 In reply to 1131.13
I should say i did not want to bring any confusion,I guess I was using someone else terminology.
I Think I should seat back and enjoy the ride.
Why not use SW?
1st price tag
2nd Constrains, Parametric, NOT where I want to go, I had enough.....
From test I did Moi is Much faster in most cases. (No Mechanical staff here, WE KEEP IT SIMPLE)
1131.15 In reply to 1131.14
Hi yannada,
Please don't hesitate to post your wishes! :) I'd rather have more information than less...
Just if something doesn't quite line up with the direction that I currently see MoI going in, I would rather sort of get that out in the open more, that way if a lot of people see problems with it I might be able to hear something about it.
> 1st price tag
I thought this might be a big reason! :) But it is just not a very big motivator for me to do exactly the same stuff as something else just at a lower price...
1131.16 In reply to 1131.10
>>Maybe I would just call it "Max chord height"...
I agree with you in that... -Petr
1131.17
quote:
stronger fillets operations : for example a fillet with a too high value should produce automatically
the biggest fillet possible, it should not fail.
I agree, it shouldn't fail, but... What is the "biggest fillet possible"? I am posting a 3dm file example with an object on which MoI didn't manage to create a fillet properly. However, I was able to manually trim and edit those surfaces to get a nice result. So from my point of view, fillet should lead to usable result at least...
Petr
1131.18 In reply to 1131.17
Maybe an option to have a 2d fillet gizmo adjuster (there is something like that in Rhino I think) could be great.
Regards,
Marc
A cool fillet will be a fillet "along a curve" so with it some versatility possibilities :)
Or better a fillet with 2 curves ! One top, and one down
Here juste one :the straight edge and one curve
EDITED: 19 Nov 2007 by PILOU
1131.20 In reply to 1131.19
Good idea Pilou!
Filleting is definetely a place where one can think of new solutions.
I whish se to elliptical fillets, where you specify two radiuses for each side of the fillets.
Very nice program, I am impressed,
Fredrik
1131.21 In reply to 1131.19
Very interesting Concept Pilou!
Regards,
Marc
1131.22 In reply to 1131.19
Hi Pilou, normally that is called a "Variable radius fillet", and it should be something that I can add in. The geometry library that I'm using supports it, I just didn't have time to figure out a UI for it for version 1.
Normally the curve is defined by specifying different radius numbers at spots along the edge, but it is an interesting idea to define it by a profile curve directly like you are showing there, that would be some kind of "scaling rail" type option.
I've added this to the wiki wishlist.
1131.23 In reply to 1131.21
Just tried the shelling on some basic computer mouse shapes, works like a dream!
One thing i noticed though is that the offset surfaces have many more conrol points than the originals. Could i be possible to have an option fo keeping the same number of points, or at least getting the number down? At the expense of precision off course.
The fillet with G2 is giving good results too, :)
- Fredrik
1131.24 In reply to 1131.20
Hi Fredrik,
I added this one to the wishlist at http://moi3d.com/wiki/wishlist as well.
This one is probably quite a lot more difficult though, the more variables and different factors that come into play, the more difficult it gets to create a clean and simple UI to control them all...
1131.25 In reply to 1131.24
Thank you Michael!
Not fot this christmas then, ... it's good to know it is on the list :)
I will try t think of good propsals for new features
Best regards!
- Fredrik
1131.26
And a suggestion from me.
I would like whatever is selected to remain selected after doing an undo or cancel command. e.g. say you go to do a fillet and for whatever reason you want to go back, when you you press cancel or undo you lose the selection. You then have to go and reselect everything again.
Don't think I've seen this mentioned before.
Nigel
1131.27 In reply to 1131.23
Hi Fredrik,
I added this to the wishlist as well. It may be a bit difficult to set that up soon though, the geometry library that I'm using is focused more on accuracy for those results.
1131.28 In reply to 1131.26
Hi Nigel,
Re: preserve selection for undo/cancel - I think that one should be feasible to get in for V1, I'll see if I can get that tuned up after the final piece of the documentation is finished.
There are some cases where it is actually preserved currently, like for Move or Rotate transformations, but in other cases it isn't like when undoing a fillet. I don't think it should be too difficult to fix up.
Thanks for bringing it up!
1131.29 In reply to 1131.18
Hi Marc,
I added this one to the wishlist page as well.
I had wanted to do something like this originally, but I bailed out on it because it was going to turn into quite a bit of work. Eventually I should be able to get to it.
1131.30 In reply to 1131.27
:: Add Offset ::
I think, it would be a nice example of MoI user-friendly-commands if offset (and also project) command allowed for automatically "rebuilding" curve or surface after running itself. It means, no exactly the same number of points for original curve and new one, like mentioned Frederic, but only minimum points within given rebuild/fit tolerance which could be set up in Moi.ini file - default value would be zero, i.e. no rebuild.
Petr
1131.31 In reply to 1131.22
Variable radius fillet : I was planning to add this one on the wishlist. You've done it for me, thanks ! ;-))
Also for me :
- Text along a path (along a curve).
- When using the Array > Dir command, an extra option to choose the placement for the last arrayed object, not the offset point as this is currently the case.
Show messages:  1-11  12-31  32-42
