I have been experiencing an issue with offset node., which I have long believed to be a bug with the NE code.
However it has been brought to my attention that issue is not repeatable, at least by another user, MO.
If there are multiple closed curves, only one object will offset as expected. The others will only offset outwards
regardless of distance input (positive or negative values). This occurs in both "Long" & "Long+" modes.
We have the same setup, excepting he is on a PC & I'm on a Mac.
As a test, I performed a manual offset on the original 4 hexagons and found the offset worked similarly for each as expected;
however curiously "Trim" option does not appear to work.
I'm not sure if this is something you can shed light on.
