Cross-section profiles
11295.1
I recently stumbled across this MoI GIF, showing how cross section profiles can be made between curves by simply dragging across the selected curves.
This looks very useful. Where can I download the command / script?
Thanks in advance.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
11295.3 In reply to 11295.2
Thanks, appreciated!
Wow, didn't know that script is so old. I've been working with MoI for years without knowing of its existence.
─ Metin
11295.4 In reply to 11295.1
Usually you can just directly loft the longer guide curves instead of preparing these kinds of sections though.
For example something like this:
Select them in order and then run Construct > Loft and set the "Closed" checkbox option:
11295.5 In reply to 11295.4
Good point, Michael, thanks! It's been a while since I worked with "MoIchanics", so I need a little memory refreshment. :)
─ Metin
