Smooth Surface?
All  1-3  4-5
11264.4 In reply to 11264.3
I worked on this a little yesterday.
First off, the model is a mess. Not quite sure how it was created.
I rebuilt it so i could generate some results.
The 2 surface michaels shows in his last post have an opposing draft angle that also crosses over itself half way through the height of the model.
A single surface in that area will never be “smooth”
We can create it without any “hard edges”, but it will have to have a wonkey wiggle that compensates for the opposing draft angles.
11264.5 In reply to 11264.3
Hi Wolfgang,
> But I need a larger radius than can be created with trim/blend.
> And I would like to determine the type of curve of the radius myself.
You might try using the Network tool in Rhino instead for that area then, in Rhino there are options for Network to make it smooth with the adjacent surfaces.
> Is it possible to create what I need with your second tip? Could you explain this to me?
Just that it's much easier to make areas smooth when they are made up of one surface instead of multiple fragments.
Show messages: All  1-3  4-5
