First of all, the density of Lead is 6.55609 ounces per cubic-in.
https://www.aqua-calc.com/page/density-table/substance/lead
Unless your lead alloy batch has gold or some other higher density metal, this tends to imply that true volume of the test Lead pour is quite a bit larger than the stated 0.3051 cubic-inches.
Does the Lead ingot/weight bulge up out of the mold?
A calculated density value of 7.21075 ounces/cu-in is much bigger than 6.55609.
It occurs to me that the procedure, to determine the adjusted volume of the mold, should be clarified.
(At the bottom is an easier way...)
To obtain the corrected Volume for a new mold, in cubic-inches:
1. Use the empiric data from the experimental pour, for the desired 2 ounce lead weight.
With input of desired 2 ounce lead weight, the conversion program yielded a Volume of 0.3051 cubic-inches for the test mold. (0.30506+/-)
(The conversion program uses a particular value for the density of pure Lead)
The actual weight of the pour was 2.2 ounces.
So the apparent density of the batch of lead being used is 2.2 ounces per 0.3051 cubic-inches, which equals 2.2 / 0.3051 = 7.21075 ounces/cu-in.
which seems crazy.
(some pour condition factors may be included in this, and "per" means to divide)
1. Run the desired weight, in ounces, through the conversion program, to obtain the preliminary Volume which will need correcting.
Assuming that a 1 ounce weight is desired.
1.0 ounces converts to 0.15253 preliminary cubic-inch mold size. (Naturally this is half of 0.30506 +/- :)
2. Multiply the preliminary Volume by 2.0 and divide by 2.2, to get the adjusted volume for a new mold.
0.15253 * 2.0 / 2.2 = 0.15253 * 0.909091 = 0.13866363 cubic_inches. (per 1 ounce weight) <<<<<<<<<
So multiply the preliminary Volume by 0.909091 to get the adjusted mold volume.
Or, using the above 0.13866363 cubic-inches per 1 ounce weight,
multiply the desired weight by 0.13866363 to get the desired adjusted mold volume.
Depending upon the mold geometry and "top surface bulge", the correction factor may be different for different mold sizes???
I've been getting confused now, so that is it:-)
Looks like you have it all sorted out. I hope that I have not made any math blunders :-)
