Some notes...
All  1-3  4-7
1124.4 In reply to 1124.3
Hi Petr,
> I usually encountered that fillet issue after making a curve boolean
> operation, so I am not sure if it helps directly.
Aha - this seems to be the root problem, I am glad you mentioned it!
It looks like I should be able to tune this up so that curve booleans won't cause an extra segment split at the "seam" point of closed curves.
1124.5 In reply to 1124.4
Hi Petr, I was able to get the curve boolean fix in for this next beta, but not the fillet fix yet. I should be able to get the fillet fix into a patch or something after the documentation is fully wrapped up.
1124.6 In reply to 1124.4
hehe... it really works!!! No tiny curveeeeeee.... :)
1124.7 In reply to 1124.6
Same result with yours Petr....
Regards,
Lish
Show messages: All  1-3  4-7
